Varitronic wiring help please
bizzly
I cant get my scooter to start and I have tried different plugs, caps. I have also removed the green ignition wire...still no spark. I also tried just putting the HT wire against the engine bolt. I got a small spark but not much. I was going to test stator with multi meter and noticed the wires are of a different colour to my standard 12v. Does anyone know what wires are which please. The wires I have coming from stator are : YELLOW / WHITE........BLUE........RED / WHITE........RED / BLACK. and I would like to know which one is supposed to be the white earth wire, the red pick-up and green LT power wire. Also, should I get the same readings as per stickys book as in the standard 12v?......I was on scooter last night and had no problems.....arrrrrghhhhh.
many thanks....I have also posted this on that other site :)
bizzly
AAAAAAAAAAAAARRRRRRRRGGGGGGGGGGGHHHHHHHHHHHHH......earth was loose on coil :oops:
