Kawasaki dampers?
sydduckett
Looking for a set of kawaski dampers plus weld on bracket setup. any advice on best place to get these. Seen some 2nd hand ones for £80, any where that sells them cheaper?
Saw this link http://www.motorbikepartsdirect.co.uk/p ... pers/2048/ would these fit?
Cheers chaps
sef
mark-b
Main scooter: SIL GP190
Readspeed do them and have them on ebay at the mo... 350168580017
J1MS
John used to do the best brackets for the Kawasaki dampers, remade bottom screws (wider) and quality weld on top brackets. sold them as Scooter Loopy when I bought mine. Im not sure if hes still making them, but if he is get a set....
sydduckett
have sent Jon at scooterLoopy a email re the brackets, any links for competetive priced Kwaka dampers?
Ta
Sef
Knowledge
Sef,
Are you sure you want Kwacka dampers? They look trick, but you don't want damping on compression, only on rebound. When you go over a bump, you want the springs to absorb the bump without restriction, and then you want the damper to resist the springs pushing the fork-links straight back down again (or else you get a pogo affect). This is why standard dampers can be compressed with ease, but are hard to pull apart again.
Kwacka dampers apply equal damping in both directions.
Martin
Martin
    Users browsing this forum: Ahrefs [Bot] and 6 guests
