Pickups - should you have to file them to fit?
sideout
:shock: Following on from my SIL GP engine not being able to rev over 3000rpm, I narrowed it down to a stator problem. So I bought a new pickup to try that. Just fitted it, soldered it up and applied araldite as per the one I took off.
When I fitted the flywheel it fouled on the two exposed metal parts on the pickup. Because it comes with a location dowel I (stupidly) assumed it would be a precision fit.... :roll:
I surely don't have to file or grind it to fit, do I?
Do you reckon it's a rogue part?
Cheers,
Nigel
mnpes
sideout wrote::shock: Following on from my SIL GP engine not being able to rev over 3000rpm, I narrowed it down to a stator problem. So I bought a new pickup to try that. Just fitted it, soldered it up and applied araldite as per the one I took off.
Cheers,
Nigel
Came across the same issue a while back - supposedly A GENUINE SIL PART k2 tested pickup ( ohm reading maybe )
Filing to fit - unless both contacts kept the same height - a waste of time - REPLACE
Get the BGM one Nigel ;-)
soosh
I filed mine on my smallie.Works fine.
sideout
soulsurfer wrote:Get the BGM one Nigel ;-)
I know, I should have :roll: I've PM'd that nice Mr Corrado. Watch this space Mike....
soosh wrote:I filed mine on my smallie.Works fine.
Cheers Shoosh. I've emailed Scooter Restorations and hopefully they'll repace it. However, I think this has tipped me over the edge to get a BGM.
The existing stator will be made to work and I'll keep it as a spare, even if it means unleashing my filing skills on it (I spent long enough learning how to! :lol: )
    Users browsing this forum: Ahrefs [Bot] and 5 guests
