barlow stage four set ups
C*NTSPEED
well folks what set ups are you running ie main jet and pipe also the timing am i right that they run around the 18 deg ?
GEMINI S.C.
BLACK WIDDA'S S.C.
H,POOL GADGE
1.7 packer - 12.5 squish - 14cc head volume - 123 main - 2.8 idle T5 slide cosa cap and carb supply hole drilled - 18 deg - augusta 6000 - jL R/hander
12.5 mm squish :shock: :lol:
H,POOL GADGE
give or take .5 then! ...what do ye think about lifting the top of the exhaust port 1mm gadge(sean) it would help lower compression, but would you have to rev the scoot harder to get it going....
Juan
Can the spark jump 12 mil then?
I'll hazard a guess the decimal point may have a slipped a point.
H,POOL GADGE
Ha Ha Ha! Oooops....1.25mm be no good at morse code would'a
C*NTSPEED
whats the recomended ring gap?
GEMINI S.C.
BLACK WIDDA'S S.C.
well i,d go for 0.3mm/0.35mm...but no doubt H/poolgadge would say 3.5mm :lol:
H,POOL GADGE
-.-- --- ..- .-- . .-.. .-.. --- ...- . .-. -.. ..- . .- ...- .. ... .. - -.-- --- ..- -. --. -- .- -. -.-. .... . . -.- -.-- .-.-.- .-.-.- .-.-.- laughing at an old man and his decimal points! work that out then......
    Users browsing this forum: No registered users and 56 guests
