Won't Run - Can't think of a more catchy title
GP240
Try/borrow a different carb.
Bilko
Main scooter: LI150
I went out to take the cover off and I'd left the petrol on because there's a puddle.
Bilko's Oily Blog
Bilko wrote:I went out to take the cover off and I'd left the petrol on because there's a puddle.
Float needle not sealing?
Bilko
Main scooter: LI150
Thanks Colin. I took the plug out, as expected, wet. Took the carb apart. Float needle seems to be moving ok. I took it out and fired some compressed air through everything.
It's running now and I'll have to keep an eye on it.
I don't know what else to do. It'll be inpossible to try another carb.
RB250 with a LC Head
34mm VHSB Dellorto
Franspeed Tourer
It's developed a bogginess up to half throttle.
Bilko's Oily Blog
Muppet
REEDS!!!!!!!!!
C’est la vie
Bilko wrote:Thanks Colin. I took the plug out, as expected, wet. Took the carb apart. Float needle seems to be moving ok. I took it out and fired some compressed air through everything.
34mm VHSB Dellorto
Franspeed Tourer
Do you think it was just badly flooded Bilko..
Bilko
Main scooter: LI150
Yes indeed, flooded.
I had a leaky seal on the bottom of the carb. Sorted that now.
I was thinking of the float too because of the leak and poor running.
I need to try and sort the running out now.
Thanks Lads.
Bilko's Oily Blog
Bilko
Main scooter: LI150
Possible second issue.
I was trying out with clip positions and then it wouldn't start. This time I popped the plug out. No spark. The last thing I thought of was the plug as I had a new one die on me midweek. But, I put on another old one in and it worked.
I'll keep an eye on it.
Bilko's Oily Blog
    Users browsing this forum: Google [Bot] and 10 guests
