SR 185 Piston
bazman
Anyone know if these are available , sr don't have any in stock at the moment.
Also can a suzuki ts185 piston be used in these kits without any modification?
Cheers Baz.
Supereibar
I have a standard 64mm one mate... PM if interested.
Best,
J.
Stokie
You can use the Suzuki piston without any mods to the barrel if you have a crank with a TV175 or RD400 con rod fitted and you jack the barrel up with a packer plate - although you might want to adjust port timings to suit.
You could buy a 64mm Race Tour piston and use the standard crank or maybe a Mugello V1 piston too. Then there are the cheap pistons for these kits that are all over ebay.
bazman
Thanks for the reply guys !
bigmuff
Main scooter: matt black indian gp
Beedspeed 190 piston with thin 1.5mm rings. piston comes in 64mm + four oversizes. £41. I am using one in my home tuned LI150 barrel with 60mm crank. You can use these in a SR barrel with standard 58/107 crank.
bazman
Cheers sorted , Jamie came up trumps !
    Users browsing this forum: Google [Bot], Semrush [Bot] and 13 guests
