Strange electrical problem
firekdp
Nik wrote: The chassis is permanently live - can see it arcing across between throttle wheel and chassis even when there is no feed to the lighting connected.
Wouldn't this suggest that the throttle wheel is live and not the chassis?
If this is with no reg outputs connected then I would be looking at the ignition circuit, it's possibly shorting to the throttle cable somewhere.
