MZ cylinder head for Lambretta 200cc
any one care to ask here ??
http://www.bmzrc.org.uk/
done a thorough search ...the only one remotely like it is the mz trophy (big ugly bus :freak: ) :(
mickdale
saw a finned cylinder head on a race lambretta at lydden
was a huge rectangular shape that looked offset with the combustion area and the head sort of extended down lower aswell with a scoop below to angle airflow up and over the head
havent explained it well sorry
mickdale wrote:saw a finned cylinder head on a race lambretta at lydden
Maybe this one...
sydduckett wrote:Chalky had a f**k off great head on his racing scoot at Lydenn but wouldnt reaval what it was off, he did give me a clue but i was pretty wan*ered when the conversation took place so i cant remeber that much. :o He also had a large scoop which was held in place by 2 springs over the top of the barrel, very simple but effective. You would have to drop the shock to get at the plug but thats no biggy.
sydduckett
I think all the group 4 ones had this sort of set up, least all the ones i saw did. Charlie Edmonds was more hidden away along with his frozen 2 stroke.... ;)
wezly
Like this?
sydduckett
Like this?
Yeah that the sort i saw, i dont think all the racers defo use the MZ, they all seem to have that rectangular oversized head but off diffrent makes of bikes. On your pics you can see the large area at the back where the barrel meets the head. It wouldnt take a lot of fettling to cut down a standard cowelling and butt it up against the back of the head. This way your always cooling the barrel whenever the engines running. May be a bit belt and braces considering what prev posters have said but would surley improve overall cooling even more..?
wezly
You don't need it any cooler that 90. Cowlings are just not needed they actually hold the heat in, also flywheel fans pick up road dust and dirt and blow it all over the barrel, meaning the fins cant work as well to disapate the heat.
sydduckett
wezly wrote:You don't need it any cooler that 90. Cowlings are just not needed they actually hold the heat in, also flywheel fans pick up road dust and dirt and blow it all over the barrel, meaning the fins cant work as well to disapate the heat.
Im sold...what about an air scoop, doesnt look like you run one so i presume thats surplus as well?
personally i would fit one
servetakid
I might be barking up the wrong tree here. But i guess this is the same scooter you posted on young guns? But i guess you have added a different exhaust and painted the crank case?
