I guess the worst is over now that it's completely stripped, saying that, just waiting for the forks to be dipped to aid the stripping of them, so, apart from the forks, I guess the only way is up
I'm gonna blast this lot and check condition of the frame internals prior to powder coating, the bodywork will then go to the panel beaters for welding, beating and finishing in primer, apart from the frame that'll be reaired, by welding the rust holes and toolbox opening bodge, and then that'll be powder coated and then back to the bodyshop for the loop to be finished and primed.
This is the legshield spare wheel carrier, is this a genuine Winter Model accessory or a common item? It bolts through the legshields
Removed all the crap covers and foam off the seat and although the original cover underneath is knackered, this looked in a nice reuseable condition...
