series 3,how much fuel in reserve?
Suede Ed
Main scooter: SIL GP200
Gents, standard tank Indi GP,how much fuel is left when flicking over to reserve? Thanks
teamsequipe
My standard Italian GP200 tank has approx. 2.5 litres reserve, but this can easily be altered by adjusting the length of the feed pipe in the fuel tap.
gaz_powell
according to :-
- the sil manual for the gp tank capacity is 8.1 litres including 0.75 litres reserve
- the innocenti manual for the gp tank capacity 1.78 imperial gallon with 1 3/4 pints reserve
1.78 imperial gallon is 8.1 litres
1 3/4 pints is 1 litre
if my conversion memory serves me right
Depends on how short your reserve pipe is but it's very easy to test just drain fuel into a container and then measure it from when you turn the reserve tap on until tank is empty
joey
...i get about 10-15 miles at a light throttle....i always run down to reserve then refill....try a run on reserve and carry a fuel can to see how far you can go....
