DC feed to power horn/brake light.
YAMLAM
I have recently gone DC on my full frame GP as per the conversion pioneered by some of the guys on here.
i want to use the BGM regulator/rectifier that i now have spare on my cutdown (untill i can afford to go full DC again ) can i use the DC output on this reg to run my brake light and Horn ? if so , how do i "wire" it in ?.
Im using a simplyfied loom that has 3 wires all joined together with one spade connector that connects to the existing regulator. these are pink (brake light) brown (horn) and a purple that goes to head set.
is it just a case of seperating the purple and brown and plugging these into the BGM DC output ?
Any help would be welcomed.
win or lose have a booze
I think that will work, use a battery charger connected to your loom wires to check. But you will need a battery as I think the output from the BGM unit is only meant for trickle charging :?
Donnie
Yep as far as im aware all regulators with the dc output are only for trickle charging batts, not for running 12v items like lights etc.
Donnie.
yep, as above
prob won't be enough without using a battery....
