Dellorto SI26 -any good?
Svint1
Gents,
I'm currently using a PHBH30 on my 60mm longstroke Polini208 engine. The exhaust is PEP2, but a Sip Road arriving next days..
I think it might is a overkill with 30mm (and the induction noise kills me!), so I'm thinking of a Dellorto SI24 or 26.
Had a SI24 some years ago, but it didn't cool the engine enough, so had some heat-seizures on long motorway trips.
-thought then that a SI26 would be better?
But does anyone know of the quality of the Dellorto SI26 carbs?
And how would it be to jet it for my engine?
Rgrds,
Øyvind
President of Roughnecks Scooterclub
http://www.Roughnecks.no
1965 Vespa SS180 (218)
1971 Vespa 90 Racer
1986 Vespa PX250 (250 Rotax on CNC casings)
1987 Vespa PX210 with Cozy Sidecar
its nothing to do with the bore size of the carb that cools your scoot and prevents siezes its the jetting /setting up
Svint1
sean brady scooters wrote:its nothing to do with the bore size of the carb that cools your scoot and prevents siezes its the jetting /setting up
OK, but I read somewhere that the SI carbs was no good of cooling engines, due to the "short" manifold, meaning a PHBH with a Malossi or polini inlet manifold, would cool better.
True or false?
But if a SI is good enough, fine with me!
But how should I then jet a SI carb?
Setup is as mentioned above, and the casings are mildly ported to the sylinder, but nothing in the inlet.
Rgrds,
Ø
1971 Vespa 90 Racer
gaz_powell
24 or 26 will be suitable as long as it is jetted correctly
would imagine 140/be3/132 then come down on the main and up the pilot by slightly should be a good start
i`ve used both and found no difference with the 26 over the 24 both were spaco
    Users browsing this forum: Semrush [Bot] and 9 guests
