LAMMY WONT GO.......
I remember Barnsley ,used to go to the Traccy club soul nites -mega
tobytyke
Main scooter: li 125/mb 225 stage four/
o yes....BUB on the decks.....rip...KTF. :fb: :fb:
tobytyke
Just to let you know the outcome,on looking up the exhaust port.i can see the bottom ring as gone walkies and had a rite laff in the barrel,thats my summer over,(cant afford new kit),so stripping down to paint the thing :cry:
Dazza
Just out of interest..what piston was fitted? Race tour?
tobytyke
all i know it as STD stamped on the top,which i would amigine,means standard..(correct me if im wrong)...anyway...its fkd am not happy and am on war path. :x
tobytyke
Just to let ya know the autopsy... (expert view)...the ring peg on the second ring,came away,causing the ring to catch and break up on the exhaust port...only 2 weeks had a expensive rebuild...now im back to the drawing board...thanks for all your help.....atleast il have a nice weekend in the pub,instead of laid covered in grease in a laybye..
tobytyke
Right, after a trip to MBD,S ...a rebore and new piston,i managed to rebuild the top end...its running nice,but just for one little niggle...second gear on occasions,jumps then settles down again...this ussualyy happens when it hits the powerband,if im carefal and just feed it thru gently alls fine..all the other gears are spot on...thanks for any replies.and thanks for the help on the previous matter. :?
Well done that man, glad you stuck with it and got it sorted 8-)
Supereibar
Im curious to know something, how did you guys bet on the woodruff key so quickly? When my woodruff key "dropped" it sheared the whole taper (it left it big enough to fit four woodruff keys) and knacked the flywheel taper as well. The bike started making a "clunc-clunc" sound, very constant and after 5 kms it stopped. The destruction on the flywheel side was.... ehm... breathtaking for saying the least. I had to take the whole engine apart and replace nearly 50% of it.
Thanks boys
J.
tobytyke
Thank fk..it wasnt that then...!!!!
    Users browsing this forum: Semrush [Bot] and 8 guests
