Augusto...........Stator....
Timbo
I'm not mechanically minded so this is a simple question and i'm not inferring anything.........but..
Has anyone fitted a Augusto and had problems with the stator shortly after....................... :?
it shouldn't do Timbo, what problem are you having with your stator? did you re-srobe your timing?
Timbo
Had it dynoed when fitted....ignition coil has possibly burnt out on a 11 month old BGM stator.....just wondering if there might be a link.....but as i said i'm not mechanically minded......... :?
firekdp
The augusto does not affect the feed coil at all. It's a simple circuit that delays the pulse proportionately to it's voltage increase (once above a fixed zener voltage).
What makes you think it has burnt out?
Timbo
A grown up got the multi meter thingy on it today........just wondered if one might affect the other.....glad to hear thats unlikely.... :)
Dazza
Just one of those pain in the ass coincidences that really screw with your head..
