Urgent help needed
Furai
Hey guys
Right i need some help i have purchased a low mileage engine with Olympia race crank and a 166 malossi kit all brand new, and had it all ported casings barrel piston the lot :).
Now then the issue ive had is with Carbs (kinda obv as ive posted in the carb section) but anyway i was going to use a 24mm with my new engine but after looking through the ones at my disposal nun deem fit for use, other than a t5 24mm so i banged that one set the jets to the very similar setup of a normal 24mm and it ran absolutely crap. So off i went to dabbers ride out and while there i met a fellow with the help of (Dangerous for those how no him) who was running a 166 kit normal crank with a 28mm carb his scooter was white and blue with Michelin on it and the number 85 with a sticker that read kwikasfuki on the side panel anyways knowing i had a few 28mm carbs at hand i went home and try one out. But now the issue is i have no idea really what settings to use at the moment i have got it going and it pulls really well but as im only going upto half throttle due to running in its hard to tell done a plug chop at 35mph and plug was a very light brown i.e if it was a biscuit it was a rich tea what is my best step forward in settings wise as i have found nothing that really helps on the forum.
ino it needs making abit richer at half throttle or between 1/4-1/2 but whats the best way todo it.
Anyways loads to take in there but all help is welcomed.
P.S if anyone knows the kwikasfuki give him a shout for me as im a dope and forgot to ask.
Furai
going to bump this as i can not seem to get a dark plug
Furai
i am running
40 slide
av266
x7 needle 4th clip i.e top
50 idle
130 main
and a 70 on the side duno what it is but sits to the top right side of the carb bottom
    Users browsing this forum: No registered users and 30 guests
