how to tell the difference ?
scootcoot
Hi, is there a way visually to tell the difference between a 125cc engine and a 200 without stripping it down ? the engine is in the scoot, it was bought as a LI with a gp200 engine , only part of the engine number is visible, i took it for a wee run and couldn't get much more than 50 out of it !! :|
am a doogal r u a doogal too....!
Stampede
Main scooter: SX200
Not really, but you can check the position of the inlet studs.... that´s the only difference from the outside.
or take the engine cowl off and look if there´s a mark on the head or you can measure the outside diameter of the barrel between the fins.
I can give you the measurements of an original SX200 barrel.
indian 200 have different ribbing on the flywheel side engine mount
scootcoot
RICSPEED wrote:indian 200 have different ribbing on the flywheel side engine mount
can you give me more info on this ?
scootcoot
Stampede wrote:Not really, but you can check the position of the inlet studs.... that´s the only difference from the outside.
What do you mean by checking the position of the inlet studs ?
Stampede
Main scooter: SX200
The distance between the inlet studs on 200cc barrels is bigger then the 125/150/175cc ones.
I can measure it for you if you want.
scootcoot
That would be a great help ! thanks..
5 ribs instead of 3 ..though the inlet spacing is more conclusive
just measured some spare barrels for you
Inlet manifold center to center:
200 - 61mm
125/150/175 - 56mm
Stampede
Main scooter: SX200
coaster wrote:just measured some spare barrels for you
200 - 61mm
125/150/175 - 56mm
:bouncing:
