238cc clasic rapido with dev tour and TM24 + FILTER
ScooterLoopyJohn
Main scooter: 1970 GP 195cc A/F s'type
71mm revtour piston(ts1 windows) classic rapido barrel, 60mm mec crank, Mikuni TM24 + ram air filter in toolbox, LTH German reed manifold. indian ign +vespa black box and coil.strobed at 2mm btdc.(18 degs) runs Li125 19x47 set up. Dev tour system
16.65 hp /13.6 ft lbs of torque with a wide spread. 5N13 needle 2nd clip down, 20 pilot 1.5 turns out, 230 main jet
Runs strong and is good on fuel. will be at shipston rally.
Last edited by ScooterLoopyJohn on Sun Jul 31, 2011 6:03 pm, edited 3 times in total.
DaveTomo
Main scooter: SX 200
That sounds like a nice set up SLJ,is that through the airbox or a remote filter? also just out of curiosity how many turns on the airscrew.
ScooterLoopyJohn
now fitted with a ram air long foam job
