Fuel Gauge
Bilko
Main scooter: LI150
I have a spare hole :shock:
So I was thinking of running a fuel gauge off the battery.
Anything I should look out for or avoid?
Bilko's Oily Blog
AUSSIE
the gauge is the easy bit, lots of different styles to choose from. its the sender in the tank that is the tricky part to find. one on ebay for a boat application that is adjustable for tank depth seems pretty good.
not sure what sender will fit in a standard tank due to restricted room
Bilko
Main scooter: LI150
Thanks Aussie.
I have a Diablo tank, but I still need to watch for the anti splash plate though.
I was considering This
Bilko's Oily Blog
Bilko
Main scooter: LI150
It is, thank you Mark.
Bilko's Oily Blog
alcoholic maniacs sc
wanting a fuel gauge fitting myself.will a px one adapt to fit.is there enough level area on the top of a standard lammy tank to fit the anchor point?
jonashford
http://www.asap-supplies.com/search/fue ... resistance
Get ur gauge and sender from here reliable and fast service faria gauge is what I use off a battery works well
thanks for that mate!!bloody brilliant.ordered, i cant wait not to run out of fuel on the M1 :oops:
JDale
Main scooter: Lambretta Jet 200
I have also looked at the asap website and am looking to order both a fuel gauge and sender, looking at the diptype fuel they are all different lengths by cm. Which is the correct length one to buy for a standard series 3 tank?
Thanks in advance :-)
jonashford
I dunno the exact length of the STD tank u can just put a tape down the fuel cap
And measure, I use a diablo tank with a hole cut in, flat plate welded to the tank with m5 bolts protuding to bolt down the sender, easy job for anyone with basic metalwork knowledge, hope this helps?
They do all different lengths of sender just measure ur tank and get the next shortest, u shouldn't run out then,
    Users browsing this forum: Google [Bot] and 16 guests
