Vespa T5 Knocing Noise??
servetakid
My MK1 T5 has developed a knocking noise. It is coming from the rear wheel. You can feel/hear it when spinning the wheel. There is no play in the wheel, and it is like a strong tapping noise when you spin the hub back and forth. It rides well, but does any one have any idea what could be causing it?
Cheers,
smiffy1968
Main scooter: Nevermind Mk1 T5
It might not be, but i had a noise like that and in the end it turned out to be the cush drive plates/ rivets detaching. Both plates were chewed up and sitting in the bottom of the engine casing, woops! :o
servetakid
Would something like that explain why there was a bit of oil on the bottom of the casing? And would it ride badly?
    Users browsing this forum: No registered users and 49 guests
