Front end vibration
simon
Just about finished the series 2 when I drive along I get a bad vibration from the front end, all looks ok nice and tight and the dampers work ok any ideas :x
headstock bearings.............?
simon
Hi sean, the headstock bearings are fine, no play on the forks also ok when front brake is applied :?:
what handgrips then............?........... :lol:
Check the front hub spindle is nipped up tight..you wouldnt be the first....Ive done it :shocking:
simon
Checked the front hub all is tight, it seem to be comming from the front wheel suspension area :(
fork link bushes perhaps try it with out the dampers or try another hub if poss
simon
Thanks for all the feedback
I took the dampers of yesterday, still badly vibrating, will try a new wheel tyre and tube before stripping the links :?
bazman
Have you maybe tightened the forks too much?
Tosh
i know it might sound daft but 1.is the tyre on rim right and have you checked the tyre their might be a bubble in it
    Users browsing this forum: Ahrefs [Bot], Baidu [Spider] and 20 guests
