Improving the Front End Handling
Just got a Px after about a 15 year break from them. Has there been any mods to help stop/reduce that weaving feeling you can get on the front end when your in 4th at 50MPH+.
- registered user
- Contact:
up grade the front and rear shocks
- Muttley McLadd
- registered user
- Contact:
Extend the forks by six inches.
Which ones? I've heard some snap.shanetv175 wrote:up grade the front and rear shocks
- Daysofspeed
- registered user
- Playstation gamer tag: Daysofspeed
- Main scooter: GP225/Rally200
- Contact:
Correct tyre pressure for starters .
What tyres have you got on it?
Bitubo or Fournale shockers if your wallet stretches that far!
Never had the problem myself with stock items fitted correctly!
Up The Boro
Bar end weights help too. They don't take the weave out, but they make it easier to live with.
- registered user
- Main scooter: gp 283 kx
- Contact:
i can recomend bytubos and sip tubless rims with pirelli sl 26's.
slightly wider rim and a hole lot lighter and a good profile tyre that gives good grip and life.
together absolutly transform a large frame !
you cant just run one rim though.front and back or the wheels will be out of alinement !
Thanks sounds great but what's a 'bytubos'grimspeed wrote:i can recomend bytubos and sip tubless rims with pirelli sl 26's.
