honda 205 burning clutches
des
My 205 kit has just gone through its second set of plates the first set were an old set so didnt think much of it the second set was a new set fitted prior to euro lambretta and they burnt out after about 200 miles.
These were a standard set of four plates the make i did not recognise more than likely indian and standard springs.
I now need to renew and was thinking of machining out my clutch basket to take five plates and fitting some taffspeed springs along with some DR springs for a vespa, i know surflex do different color plates for different applications what would be best advised and are adaige plates better than surflex.
Any advice greatly appreciated, if i had the money i would fit one of the many new all singing and all dancing clutch kits currently on the market but i cant afford to.
wack 63
Main scooter: '71 GP TS1
I think you have answered your own question there-don't use the indian ones.A set of 4 plate Surflex 'B' and Taffy springs should do you unless you have a monster motor :)
Also, are you using an odd gearbox combination?
des
Muttley McLadd wrote:Also, are you using an odd gearbox combination?
No standard SX150 gear box
goldeneye
did you change your steels as well as the corks? if they wear "blued" they will wear out the corks in double quick time. surflex "B", thin top plate, MB springs.
des
goldeneye wrote:did you change your steels as well as the corks? if they wear "blued" they will wear out the corks in double quick time. surflex "B", thin top plate, MB springs.
Yes new steels fitted as well, have ordered surflex B plates and MB springs so hopefully that will sort it, thanks for the advice.
    Users browsing this forum: Semrush [Bot] and 10 guests
