Blending a TS1 Barrel to Case & Mag housing...
J1MS
Been out in the Garage today trying to finish a TS1 blend that I started last week...thought I would try and show a little of how I did it and some of the tools used to help make it easier...
First of all a standard case unmodified...
Then the case I started last week and a tool I use for getting in at angles that are awkward without it...
This is a Proxon right angled ac mains powered 90 degree hand piece Too large for transfers in the bore but good for getting at the base of the case where the mag housing meets the case for a neat blend...
This shows how it can access the base with ease and at an angle that's lets material be easily removed... I had made a start but stopped to take this pic...
Using rubberised aluminium grinding bits, this after opening the transfer port and blending the mag flange to size the finish obtained is then with a flex drive and about a dozen rubberised bits for each transfer
and a shot of the casing one transfer opening smoothed the other still rough ported... the finish is a contrast tungsten's on one side and aluminium rubberized bits...
this shot to give an Idea how much metal has been removed..
The metal that's been removed is only to allow a better feed to the smaller main transfer that on a standard barrel gets not such a good feed It now has an area about 50 % larger... The port could be bigger all round, but I see no real need to do this, as its only supplying a standard port that has only been enlarged in the feed area down the barrel, but not in the bore... but it could do with a little tidy up in the bore... Maybe later
The reed block has already had a little work done to it the effective area at the tip of the reeds is about 20% bigger and the flow should be quicker through this reed block than a standard and the reeds have been trimmed all round... I posted this elsewhere but as its for this engine I thought I would put it on here..
Standard reed block...
modified block...
Standard reed on left, and modified reed on right, slightly smaller and finished off with fine wet and dry...
This is the barrel that its being blended to, the tansfer feeds already enlarged and matched to the pack piece the pack piece then bolted to the casing to effect a good blend.... This pack piece probably wont be used but another better blended pack piece will be used in the end...
J1MS
In case anyone wants or needs to buy the rubberized bits for cutting smoothly into alloy (they will slowly remove Alloy and leave a polished surface with a little practice) there available off ebay, I think I payed about £15 for a box of assorted bits approx 100... some small some larger... but all useful sizes... I will let you browse ebay for them they also sell very cheap Tungsten burrs as well... Hope this info helps or encourages others to pick up a die grinder as there arnt many experts out there just people like me and you that have a go... but some are very very good at this... Myself I'm just good enough to make a scooter a little faster, sometimes.... but not always... Once re-ported one of my favourite SIL barrels and lost all the top-end it once had :? ... but this taught me what not to do :smug: ... and I have never repeated these port timings on another barrel since... :lol:
oldbiker
Proxxon, is that the tool from touchstone tone woods, in millersdale
Bilko
Main scooter: LI150
JIMS, this is a great post. You might have just given me the confidence to have a go at this.
Thanks for sharing.
Bilko's Oily Blog
steady on there JIMS................ :lol:
but to just warn you...............
if you carry on/and persist in producing these very interesting articles /topics .....
we may have no choice but to consider promoting you to" scooterotica official tuning advisor" .......or "moderator" or something.......... :D
well done matey..........great helpfull posts................... :D
J1MS wrote:In case anyone wants or needs to buy the rubberized bits for cutting smoothly into alloy (they will slowly remove Alloy and leave a polished surface with a little practice) there available off ebay, I think I payed about £15 for a box of assorted bits approx 100... some small some larger... but all useful sizes...
Any links to these? I couldn't find them on ebay.
Bilko
Main scooter: LI150
I'm looking too and can't find any anywhere.
Bilko's Oily Blog
I got some eventually off Ebay, I think they came from Hong Kong. I got 200 as you go through them pretty quicky. No longer got the link though.
Edit.... see post below.
Found them in my feedback details..
http://cgi.ebay.co.uk/Assorted-100pcs-R ... 2a1146ee5c
Bilko
Main scooter: LI150
Nice one, thanks Martin.
Bilko's Oily Blog
    Users browsing this forum: Semrush [Bot] and 8 guests
