No kickstart - clutch engaged
BadBob
Just bought a very low mileage px200 engine taken out of a stolen/recovered scooter that had been stored for a couple of years. Kickstart does not engage, just feels as if the clutch is pulled in even though cable is obviously disconnected.
Any ideas what the problem is here?
Cheers
Rob
ducksta
are you sure the teeth on the kick start arnt smoothed off it happend to me once and it felt like clutch was stuck in
H,POOL GADGE
Hole in the piston.....
Clutch woodruff key,circlip off clutch,clutch siezed or missing :lol: Does the piston move?
BadBob
Cheers for the answers so far. Piston/flywheel doesn't move & kickstart mechanism all seems to be working fine. I think it's got to be something internal and need to look. Woodruff key/ clutch seize looks most likely at the moment I think.
fraserp200e
Main scooter: 1988 MotoVespa TX200
BadBob wrote:Cheers for the answers so far. Piston/flywheel doesn't move & kickstart mechanism all seems to be working fine. I think it's got to be something internal and need to look. Woodruff key/ clutch seize looks most likely at the moment I think.
I've had this happen to me - it turned out to be the circlip on the clutch basket had sprung out.......it's worth checking that first as it's a relatively quick fix.
1983 Vespa PX125
1984 MotoVespa P200E
    Users browsing this forum: No registered users and 69 guests
