30mm too big?
#1GP200
In the process of building a 185 alloy kit with a 42mm Rayspeed clubman.
Was intending to buy a new 26mm or 28mm Dellorto.
Found an old 30mm PHBH Dellorto and was wondering if it would run ok or be a bit too big
and cost a fortune in fuel.
What do you think people...I know nuffink about carbs.
lockman69
I am sure the 30mm carb would be fine, if you already have it and didn’t want to pay out for a new one.
Personally I would use a smaller carb and use a lot less fuel...
I have a 30mm PHBH carb on my 230 TS1 and its great for my engine
#1GP200
Cheers Lockman, was thinking it was on the big side.
Been looking at carb set ups on various sites, time to bite the bullet
and fork out for a new one. Thinking 26mm, seems to be mid-range option.
I've got a 30 mil on my 185. Set up right, it'll be fine on fuel. Mine uses less on a run than a standard 200 with a small carb on it. About a litre less per 80km.
I ran a TMX35 on a previous 185, and that was ok on fuel too.
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
