clutch springs question
sydduckett
I dont think the springs i have in my 5 plate clutch are quite up to the job. I did have a centre spring in prev to this and it worked fine but was hard work on the wrist after a while. Twinny has suggested putting vespa springs over the current ones. Question in have is would this be more or less stiffness on the lever over that of a centre spring or not.... :? ?
Ta
sef
a lot less pressure on lever sef
sydduckett
mark wrote:a lot less pressure on lever sef
Cheers mark, working from home tomorrow so will will buzz you then.
rbgaz
y u got job then sef ? lol
sydduckett
What i mean is the mrs and kids are out so can do a bit of work... :D What happened to you sunday, couldnt make the whole trip... :D
