110 rod crank
wack 63
Main scooter: '71 GP TS1
Does anyone do a 58/110 good quality crank,not a mega expensive one though?
grimspeed
Main scooter: gp 283 kx
BGM !
BGM cranks are a myth, I've never seen scooter-center have one of any description in stock. I'd imagine that MEC make them, I've had a 60 x 110 Mec crank.
wack 63
Thanks Martin I was going to contact you just incase you had one but after searching all the dealers all the 110 rod ones are 60 stroke and my motor is all set up for 58.Will be having my crank welded for now.
Grampians in Liverpool will put a 110 rod in a SIL GP crank, but you really need the web faces maching slightly first.
Harry Barlow will re rod a crank for you too.
eibargum
Chiselspeed will also put you a 110 yam rod in SIL webs if you cant get what you want.
wack 63
Thanks chaps I have now got sorted :)
