reparing a flywheel
goldeneye
ran one with a couple of fins missing before, didnt have a problem (only a stage 4 200, but soundly walloped all ower) i fit the plastic fans on totally knackered ones with "NO NAILS" , or sticks like shite to a blanket, or whatever its called , and some m5 bolts tapped into the remnants of the flywheel, with big washers to spread the pressure. doing one for me jet motor. (you can get placcy fans off autos from the breakers, cost buttons if you can be bothered to rake around)
mawso
Had a fin drop off my Ducati flywheel today. It appears to have been chemical metalled and araldited previously. It has 2 tiny drilled holes too that are ful of hard resin. Had kept it to pop back on (somehow), misplaced it (in the pub) since.
A friend has cut a bit of piston skirt up before and blobbed it on with araldite...he says it's still in place!
