Main jet advice
tomdavid1988
Whats a good starting point for jetting on an LI125 with SR185 kit with polished ports etc, Jetex 22mm and a taffy replica pipe, 128?
bristolmod
I'd start main at 125 and work up or down from there
Everything else on the Jettex as per GP200
Scootering since 1968.
tomdavid1988
Thanks Chris, any idea on what plug to use?
TS1-200
I`ve just put an SR185 kit together, for a mate, although using a Clubman pipe. a 122 M/Jet seems about right with the other jets etc. as per Standard GP200. didnt do any major porting though, just cleaned up existing where the liner didn`t exactly match up with the ally casting, and where the casting was rough,it goes quite nicely, I can see that if you know what you are doing porting wise you could make a good cylinder out of it,
Keep on keepin on
    Users browsing this forum: Amazon [Bot] and 1 guest
