Base gasket turning to mush
Chutney Brownlove
wack 63 wrote:Although there was some dodgy gaskets out there,the main reason the gaskets are disintergrating is the cylinder moving and rubbing.
I thought this was a wind up. :( :?
Thanks, the ones in the picture above i'm talking about. Bought seven, three used and all failed. Still got four hanging on the wall to remind me not to use them. :roll:
I prefer to use just sealant but sometimes use gasket to get timing or squish right.
A failed gasket will make your nuts loose, so will knackered stud threads.
