chrome ring head or not
boxofbits
Can you add a non chrome ring head set to a chrome ring bike by taking a bit off the bottom of the head set - or is the stearing lock in the wrong place etc--
i wouldnt recomend it mate
boxofbits
how can you tell the diffrance between headsets is it just 9mm or
something
sydduckett
boxofbits wrote:how can you tell the diffrance between headsets is it just 9mm or
something
There the same apart from there is more meat below the steering lock on a non chrome ring. You can machine it off but its hassle as the front of the headset intrudes into the base of the bottom headset.
not sure if this helps. sticky talks about this in his book
what head set do you need ...i have a ring type li one
Daggs
boxofbits wrote:Can you add a non chrome ring head set to a chrome ring bike by taking a bit off the bottom of the head set - or is the stearing lock in the wrong place etc--
It's rather easier to remove the chrome ring and replace the top bearing. If you care about having a steering lock, it just means welding a small piece of steel on the fork tube.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 7 guests
