offcenter scootrs outboard disc brake kit
Robi D
I've got a scootrs kit and one side is 1 inch to the fork leg the other side 1.5 inches the fork leg. What causes this? Is there a way to fix this?
10 inch Terror
Xbox live gamer tag: No.
Have you had any damper mounts welded to you links? I had the same problem with both a Scootrs and LTH brake. It turned out to be due to my links warping when i had damper mounts welded on them.
Robi D
No, just have bolt on brackets! Thought about eelding them up, I even made a jig for it.
Robi D
Wow! That was some of the most retarded crap I have ever read!! I don't really even remember if my question was answered! :shock:
Robi D wrote:Wow! That was some of the most retarded crap I have ever read!! I don't really even remember if my question was answered! :shock:
Well use the search button some more, this subject has been brought up several times before.
10 inch Terror
Nice cheers.
ArmandTanzarian
I assume you're referring to the other thread. Unfortunately any post containing the word "ScootRS" is obliged to degenerate into abuse within 10 contributions. Apparently its a forum rule.
    Users browsing this forum: Majestic-12 [Bot] and 3 guests
