uncontrolable revs!
marteibar
Main scooter: Lambretta Eibar LI150 s3
I have just re-built my LI150 engine and am now running it in, after riding it for a couple of miles when i engauge neutral it revs its nuts off and i have to turn the engine off!
Any ideas please.
bristolmod
1) Throttle cable snagging somewhere, or, more likely
2) air leak when warm (inlet manifold; exhaust gasket; head gasket; crank seals)
Chris
Scootering since 1968.
sydduckett
slide in the wrong way...not that iv done that you understand... :D
marteibar
Thanks guys, i'll check for an air leak, my slide is in the correct way, i can't believe any one would put it in the wrong way! lol. :D
marteibar
All sorted now and running well! :D
Bofs
What was it?
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
marteibar
Hi Bofs, I had used the wrong gasket sealant, i used the red hermatite stuff and not the Blue high temp silicone sealant.
bristolmod
? that won't affect it
marteibar
All i know is that it's done the trick, although the cylinder bolts could have been a bit tighter!
Mart
    Users browsing this forum: Google [Bot] and 23 guests
