which kit?
carbon lammy
thinking of a new kit,got a monza 225 but not happy with it,thinking of trying a mugello or a mb factory 225 kit,just want reliability and pulling power not a missile,will be running a 30mm delly and a dev tour or big bore gori,need opinions of which is best kit,cheers
What's wrong with the Monza?
carbon lammy
keeps eating pistons first i had 35mm tmx with fat mamber dynoed, piston at bottom near exhaust port between top ring and crown broke away,then 30mm delly with dev tour again dynoed,running sweet as a nut no smoke tick over all day,head came loose took it off to check gasket piston done same as before,sent kit back to cam lam for them to have a look at,they said never seen it before,wating to see what they have to say?
rocho68
carbon lammy wrote:keeps eating pistons first i had 35mm tmx with fat mamber dynoed, piston at bottom near exhaust port between top ring and crown broke away,then 30mm delly with dev tour again dynoed,running sweet as a nut no smoke tick over all day,head came loose took it off to check gasket piston done same as before,sent kit back to cam lam for them to have a look at,they said never seen it before,wating to see what they have to say?
contact chris sturgess , hes just done a barrel that was the same as above the bore was distorted , new steel liner and porting work = 30bhp !!!!!
The Supertune Avanti is out in a few days. That's got to be worth a look.
    Users browsing this forum: Baidu [Spider], Google [Bot] and 4 guests
