Ancilloti clubman
Paul perks
Main scooter: Lambretta LI 125 Special
Has any used a ancilloti clubman type exhaust on a tsi if so what is it like and do you have change the jetting in your carb any advice will be good many thanks
ArmandTanzarian
The Ancillotti is the best clubman I've ever used. The performance was almost as good as the JL expansion that was on before. Not too loud and reasonably priced too.
Trouble is, those crazy Italians decided to make them out of cheese instead of steel. I had to weld mine back together four times before I gave up. As fast as I repaired it, it would rip apart somewhere else. I've seen plenty of posts on here saying the same thing too.
cezeta
my ts1 was built in the mid 90s by mbd with a mbd clubman. it was dynoed at taffspeed with 18bhp but with no peak just a constant 0-8k rpm of power which is easy to use.
i like them, others dont but i think its a good set up.
i would use at the time a clubman or a kegra race pipe and never bothered to change the jetting but thats not to say that you will not need to.
mbd bring out a clubman soon with the same is power as a devtour pipe. this could be better still.
soosh
Ron Moss at Supertune already has a bigbore on the market,from what ive heard,they are supposed to work great on a TS1.
Im sure i read here that Diablo did a dyno for a customer with one on a TS and was very impressed.
Dimitrios_231
Ron Moss big bore,
better exhaust than the JL3 and all the other clubmans I've tried (Casa,AF,Sito).
mickdale
soosh wrote:Ron Moss at Supertune already has a bigbore on the market,from what ive heard,they are supposed to work great on a TS1.
yeah soosh - was my ts1 230cc
very nice results on the dyno but loud - much better than 48mm big bore clubman
soosh
You sticking with it still though? What did you have on it before?
cezeta
is yours the baffled or baffless one?
mickdale
dunno - just stuck it on for the dyno along with some others on the same day to get a direct comparison
    Users browsing this forum: No registered users and 83 guests
