jet engine mount cone
mickdale
got a 1973 jet
what engine mount cones do they use?
li series 1, 2 & 3 or TV, SX, GP
cheers
mick
wack 63
Main scooter: '71 GP TS1
Check Stickys book,but if it has wide engine mounts then it uses the cones with the flat bit on the taper.
mickdale
will the wide engine mounts be in relation to the engine case or the frame mount tube?
cheers
mick
wack 63
The mounts in the casing
mickdale
thanks for the info
    Users browsing this forum: Google [Bot], Semrush [Bot] and 66 guests
