Disc brake
Dazza
I'm looking into fitting a front disc brake, I'm torn between the outboard and inboard hydraulic , are there any major differences in performances between the two?
Dont know about any differences Dazza but my scootrs anti dive front disc brake is brilliant mate, the difference it makes to riding and the confidence it gives is worth every penny of which ever you choose.
Dazza
My standard brakes are actually very good, although I got on a P2 disc the other night and had forgot how nice a front disc is,birthday is coming up so might treat myself
paulmgreen
I would choose outboard Dazza. Make sure you use a decent hose I.e. Chiggy's at lambrettaupgrades.com !
www.JPPLambretta.co.uk
Dazza
Cheers for the replies folks, outboard it is then...
paulmgreen
.... and try and find a Nissin Caliper too!
scootRS.com
Outboard performs much better. Inboard you have 1 small piston pressing 1 little pad pressing on a disc and pushing it against another little pad. Outboard you have 2 pistons pressing on large floating pads on a stationary disc.
That isn't to say the hydraulic inboard can't serve you well enough. Of course, semi-hydraulic introduces more mush into the system.
We strongly considered redesigning the inboard disc when we cast ours but kept it original.
Cheers.
