MB digital speedo
doggbhoy
i disconnected rev counter,speedo fine now :)
bizzly
doggbhoy wrote:i disconnected rev counter,speedo fine now :)
Ive just done the same and the speedo works fine for now :lol:
jonashford
Ive had one of these speedos since my scoot went back on the road in feb, It does mist up when I take it out of the gare and the sun is shining, then after about ten minutes it clears up, I think there must be somewhere where a small bit of moisture gets in to it somehow?
Other than that its worked great, until my plug cap broke & I replaced it with a rubber waterproof ngk type, then the speedo was all over the place. I changed to a normal ngk cap and all is now fine in the speedo world again. I havent got a complaint about it really. The misting is not a big deal.
I run it off a koso ac/dc rectifier, no problems there either
I wonder if this is the reason why SIP adopted they're design using the speedo drive?
jonashford
Not many new ideas come without theyre faults... big or tiny...
"Along with the sunshine theres gotta be a little rain sometime"
:lol:
