grips and bar ends
camel
hi all...just coming to the final stages of my winter re-vamp of my series 2 street racer,some nice grips would finish it off nicely,any recomendations?and how do you use bar ends if i chose to do that?any pics guys?
the bike is black n silver
I got some off e bay with bar ends moulded into the grips decent quality and price...playlife there called.
camel
i like the look of the cnc alu anodised/rubber type,i think pm stock them and ebay...but they only seem to come in 7/8 diameter,can they be squeezed on,arnt lammies 1"
i made my own
non that i know off actually fix to the bar itself and these give the right lenght for 125mm sports bike grips
camel
what you do just weld a nut inside to bolt the bar end too?
no its a bar extension with an m8 thread to which is bolted a motrax bar end ,the extension is also an end weight and replaces the plastic rod end also ,i have the dimensions and more can be made easily
Do bar ends make much difference on a Lambretta?
theory is they damp vibration and lads that i have had them made for recon they do
sydduckett
RICSPEED wrote:no its a bar extension with an m8 thread to which is bolted a motrax bar end ,the extension is also an end weight and replaces the plastic rod end also ,i have the dimensions and more can be made easily
Would these fit a series 3 end as opposed to a GP...?
cheap epay ones and TZR grips total cost £11 a scooter dealer was selling something almost the same for £27 i welded some 6mmx22mm discs to the end of the bars with a 6mm hole in them for the bolt
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 11 guests
