PK125 engine in a 50 Special ?
Does a PK125 engine fit straight into a 50 Special frame ?
What's to look out for ?
most importantly, does any of the frame need cutting aout ?
It's an electric start motor, but will not be using that.
thanks
yes mate thats whats in the wifes
Juan
Depends on if it's a 2 or 3 stud inlet manifold.
Presuming you're running the standard carb swop the PK inlet for a Primavera one if it's 2 stud casings but a 3 stud motor will mean trimming the hole in the chassis as they run a differant routing.
thanks, will pass that on
pop over at weekend and have a look, got something to ask you anyway
mark wrote:pop over at weekend and have a look, got something to ask you anyway
cheers, will do. You can ask me somrthing before then though 8-)
    Users browsing this forum: Semrush [Bot] and 15 guests
