Varitronic flywheel options
red ghost
Main scooter: lambretta gp150
All the threads on my Varitronic flywheel are now stripped, made from cheese I believe..
Is a center boss available seperatley?
I can repair the fan threads and have a think about the center thread..
If I buy a new flywheel, that's another AU$300, which will make it an AU$900 ignition kit :?
$300 can get me a new af/bgm ignition kit from SCK
Bilko
Main scooter: LI150
Can I ask how you removed the flywheel? I've a Varitronic flywheel that I need to remove with knackered threads. Mine were made of cheese also.
Bilko's Oily Blog
red ghost
Hi Bilko, I made a puller which utilizes the 4 M6 threads for the fan, but that failed due to the cheese factor, so I tried with the center boss thread with a regular puller one last time and it worked..
Bilko
Main scooter: LI150
Ok, thanks. Sorry I can't answer your question by the way, but I may be looking a boss too for mine from my Muggy 225 engine.
Bilko's Oily Blog
martinr
will your flywheel puller still go in . if it will take out centre bolt of puller push it into flywheel as fas as it will go .the drill holes through flywheel nut shape into puller stick some bolts in the holes put bolt back in centre of puller and screw it in this should pull flywheel off :D
Bilko
Main scooter: LI150
Thanks I'll give this a go, it's on my old Muggy 225 engine, which needs an overhaul. I should be starting that next week.
Bilko's Oily Blog
    Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 2 guests
