LI s3, revs rising, suspected air leak?
lammysilver
Helping my friend with his S3 LI on the weekend (125, 22mm carb, standard exhaust...), all seems very standard.
It starts after few kicks, doesnt idle at all, after a while the revs rise fast when in neutral at lights etc. making it unridable.
We are just after a few pointers of whats worth checking over before we start and suggestions as to what the cause may be.
cheers
Sticking throttle cable maybe. Replacing the cable will be a cheap DIY to rule that out.
Clean carb and fuel tap
Head gasket
exhaust gasket
Inlet gasket
Mag gasket
Oil seals
Base gasket
Just a few to be going on with
paul213
also consider lack of fuel , blocked breather , fuel tap blocked etc
