pacemaker question
sydduckett
Im thinking of getting a pacemaker box but have been told that there are weker ones that should be steered clear of.. :? I understsnd there is a measurment you can use to identify them? Does anyone know what this is where you should measure from too? Also any suggestions for easy identification when buying online?
Sef
tarmac tickler
its the early ones that are weaker, its third gear, you have to measure across 3 teeth to find the weak ones,, i will have a measure for you tomorrow as i cant remember off hand what it is.. if you had the gears in front of you its easy to see the weaker ones as the teeth look thinner than on the other gears
phil23fair
Straight out of Stickys book. The weaker gearbox is the early one. Its gear cluster is bored for a clutch centre spindle and the measurement for the 3rd gear across 5 teeth is 33mm for the early box and 33.8 for the late one.
Phil
sydduckett
tarmac tickler wrote:its the early ones that are weaker, its third gear, you have to measure across 3 teeth to find the weak ones,, i will have a measure for you tomorrow as i cant remember off hand what it is.. if you had the gears in front of you its easy to see the weaker ones as the teeth look thinner than on the other gears
ta.. ;) :D
sydduckett
phil23fair wrote:Straight out of Stickys book. The weaker gearbox is the early one. Its gear cluster is bored for a clutch centre spindle and the measurement for the 3rd gear across 5 teeth is 33mm for the early box and 33.8 for the late one.
Phil
Thanks phil, whats the general feeling on the Pacemaker box, i have an indian GP200 on my rb20 and im happy with the way it goes. Pulls up hill and only a slight gap between 3rd and 4th. Some of the teeth are slightly chipped/worn and this may be what is casuing it to jump out of gear. Hence the reason for looking at the Pacemaker. These do seem very expensive though (£130). Should i replace the indian box with like for like or invest in the pacemaker. Have 18x47 by the way
Ta
    Users browsing this forum: Google [Bot] and 24 guests
