Anyone know the paint code for Vespa metallic green?
ArmandTanzarian
The one that they used on a lot of bikes in the early 50s
I have a Lechler book with Piaggio colours, Verde Met (metallic green)Year 1950 Code 1211/M or 8003, Year 1951 Code 1212/M or 8004.
It also has blue & grey from that era, possibly the other colours in your picture.
I'm not sure the difference in the code number and the formula number (80**) but for Lammy paints I have used the 80 numbers and it's woked fine.
Hope this helps - I wouldn't make up too much on your first tin though just in case.
Rich
ArmandTanzarian
Someone on the VCB site says its Max Meyer 6002 an so no I'm confused
Max Meyer will have there own codes for the same colour ....if you want lechler you need a supplier that uses those codes
Ian Hepworth
Isn't the ET4 colour the same?
    Users browsing this forum: No registered users and 68 guests
