Legshield glovebox mounting
Stampede
Main scooter: SX200
Want to fit an PE glovebox to the legshield of my SX.
I´m currently thinking about the right way of mounting it - it´s an original PE one, so it has to be matched to the legshield first.
Has anybody some pictures of your way of mounting the glovebox?
I think the lower screws can be hidden behind the front mudguard, but what´s about the ones at the top? Maybe behind the horncasting?
Awaiting your thoughts.... :D
lamblast
just done one on my gp bottom pieces to the mudguard bolts, at the top i welded a plate to the legshield spine and the welded a bolt to this you carnt see it so i wasnt bothered i made my toolbox very slim them mounted my spare wheel to it .
i welded bolts to the leggies
petemaisey
My method was to fix the top in a similar fashion to a toolbox top fitting. A small keyhole shape upsidedown slot in the legshield centre.
Put a hex bolt head first into the slot, tighten a washer and nut onto it to hold.
An "L" bracket fixed inside the legshield tool box to line up with the bolt.
Fix with another nut and washer.
Pete
