Touring kit with tm24 and ADS3.
giankx
The only thing that i doubt about that kit is why testing a "touring kit" with a 39mm carb?
soosh
I thought that too but will wait to see the final results.Im sure all will come good.Its not as if he has just read a book on it and knocked it together in his potting shed.
soosh wrote:I thought that too but will wait to see the final results.Im sure all will come good.Its not as if he has just read a book on it and knocked it together in his potting shed.
Didn't he write a book and then knock it together in his potting shed?
soosh
:D
joespeed
giankx wrote:The only thing that i doubt about that kit is why testing a "touring kit" with a 39mm carb?
so you can use 1/4 throttle and save juice and open it up to pass the 'ferro rocho' in the fast lane!
Muttley McLadd wrote:Didn't he write a book and then knock it together in his potting shed?
Also being tested are 30mm VHSH, 34mm VHSB and something called a jetex (whatever that is).
And, for clarity. It's not a potting shed - it's a cow shed. :bigsm:
soosh
So he has designed that in the dairy? :o
What a guy!!
grimspeed
Main scooter: gp 283 kx
myself would start with a rapido classic cylinder and go from there ! er 250 piston.
