wont start
Piatti wrote:Timing set with TDC tool and timing disc, then when arrow on outer edge of flywheel lined up 19 degrees I adjusted the pick up on the stator plate to match the marks on the inner flywheel.
Did you use the TDC tool in the way that Ricspeed described, if not you will be way out :?
firekdp wrote:
RICSPEED wrote:
dapper wrote: If you are going on the timing marks on the flywheel, they could be out.
...put in head and mark the point on your mag housing by Turing flywheel buy hand both ways until it cant go any further ...mark both points and half way between these is tdc
Piatti
Yes, using the TDC tool turned the flywheel one way then the other. Then used timing disc to find the centre of the two points. Followed the process as on Scooter Techniques lambretta engine rebuild DVD.
Been told to pour a thimble full of petrol down the spark plug hole and try to kick over, this has not worked either..
I have noticed that the noise is different when I kick it over with and without using the throttle, could this be an indication of anything :?:
regards
Piatti
dapper
Difference in sound is probably induction noise with carb slide open. Check that choke is operating correctly, and try not to flick throttle open when trying to start
Piatti
dapper wrote:Difference in sound is probably induction noise with carb slide open. Check that choke is operating correctly, and try not to flick throttle open when trying to start
I'll check choke tonight and try kicking over again....
ratty
Main scooter: LI ser3 125 {TS1 230} 1963
if you have a spare coil (cdi) try that,have had the same problem myself,also use stickys book to check the resistance across the stator coils, you will get a good spark but it wont be strong enough to fire up if you have an iffy coil or black pickup.
how much!!!
storkfoot
Dodgy cut out switch, or ignition switch :idea:
Piatti
Checked choke and its ok, still no start........
Piatti
ratty wrote:if you have a spare coil (cdi) try that,have had the same problem myself,also use stickys book to check the resistance across the stator coils, you will get a good spark but it wont be strong enough to fire up if you have an iffy coil or black pickup.
What do you mean by a black pick up :?:
joey
:roll: ...you'll probably find the engine totally flooded with fuel now...take the plug out,put it in first gear full throttle,no air filter,and push it as hard and fast as you can for 10yards +...this will clear all the flooding fuel/oil out of the engine...once you've got your breath back n had a shandy refit clean gapped champion N3 plug,fuel/choke/ignition on,off stand try a couple of prods on the self starting lever,try a few times,try different throttle openings......if this fails try bump start..run with it carb side,flick into second[no clutch] bump the seat with your arse...then push like f**k..try different throttle...should do the trick...enjoy! ;)
Mickey C
Feeling your frustration Piatti.
dont want to confuse the situation further but if bump start has not worked you will be both knackered and migithy pished off.
others on here will know far better than i but i've also had wrong jets in the carb that made mine an equal nightmare to start - what engine - carb - exhaust set up have you got?
