ebay 225 oko/pwk 30mil or 30mil delly
Danger
Main scooter: lambretta TV200
jetting advise needed , ebay 225 kit mick abbey fast road tuned, jl3 pipe , oko/pwk 30mil also have a 30mil delly if that would help, with my setup GP200 gearing 18 x 47 thanks lads
Danger wrote:jetting advise needed , ebay 225 kit mick abbey fast road tuned, jl3 pipe , oko/pwk 30mil , with GP200 gearing 18 x 47 thanks lads
Just PM'd you Danger but at a guess Idle Jet 36 or 38, Main Jet, Start as large as possible 150 if you have one and work down from there. Needle will be fun, play with the clip to sort out the mid range and I'll dig out some info I have on interpeting the letter codes.
One thing about the jets, the number relates to the metric size of the hole so a 150 is = to 1.5mm handy to know if you stuck and have some very small drill bits (£9.99 in Maplin ;) )
Danger
cheers coaster got it replied back
Danger
i can if need be get my hands on a 30mil dellorto if that would help anyone with my setup
