PSI Tyre
Den 08
Main scooter: lambretta Gp 225
hi all just fitted scwalbe weatherman to my gp what psi should i put in it states 44psi max
but seems a bit high i'm using tubes on standard rims. i'm 14-15 stone :oops: helps to keep scot on ground :lol: :lol: i also noticed that there is'nt alot of room between tyre wall and engine case about 4mm should this be of concern?
Den
J1MS
about 18-20 front and 28-32 rear is the normal. 44 psi... is for the tyre to support maximum tyre load, and not for the use you will use it for......
on my series one i run 44 psi 2 up (25 stone approx) and 60k in the trailer ,just get mates to keep an eye on your tyre shape when riding (well thats what i do ) :?
the best setting for tyre pressure FOR YOU will vary as to your use/load.............
and is best found from experience/familiarity with your own machine..........
but typically,.......if you find that your tyres quickly go bald in the middle............its over inflated.................. :D
or if side walls look cracked its under inflated :)
Den 08
thanks all :) :)
Den
noggin1969
Or if it handles like a pissed up hippo .......its flat :lol:
Has a mind full of useless s**t and isn't afraid to use it !
cryogenic
Hi Den what size tyre is it your running on i run the weatherman 190 / 10 on the rear and the paceman on the front both on standard rims wide rims wont fit with this size of tyre on the rear due to engine casing clearence i ran at 35psi to sweden and back. A little wear was noticed but i put this down to over 2300 miles being covered and i was towing a trailer.
kind regards :)
I RAN OUT OF SICK DAYS SO I DECIDED TO RING IN DEAD
Den 08
32 in rear 28 in front
100-90 on standard rims
done about 30miles today felt good no marks on engine case tyres nice and warm.
going to sandford tomorrow i'll give'em a good run :!: :!:
Den
Dazza
noggin1969 wrote:Or if it handles like a pissed up hippo .......its flat :lol:
Have you ever ridden a pissed up Hippo then Shaun?? :D best not answer eh? :D
