26 years later
does no one walk down your street???
if i had spotted it there id have been braying on yer door
C*NTSPEED
dont do lammys but im looking forward to the work in progress pal
GEMINI S.C.
BLACK WIDDA'S S.C.
C*NTSPEED wrote:dont do lammys but im looking forward to the work in progress pal
yes you do .................. :frog:
it just has a vep'o motor :lol:
Devlam
Main scooter: Lambretta Li150 Special
Progress slow at the mo. Waiting for engine to come back before starting rebuild.
Just about given up on getting a decent original mudguard. Any recommendations on new/remade LiS style mudguards? Prices vary -- I've seen £50 at Riviera Scooter Parts to £84 at Camlam and then beyond.
Where is good for quality remade body parts?
Devlam wrote:Progress slow at the mo. Waiting for engine to come back before starting rebuild.
but have you put a wanted on here ?? ;)
Devlam
Have now - obvious really -- doh!
Devlam
Ummm - so make that 27 years then :oops:
All work stopped on this last year as I had a building project on the go at the same time which took all my time and more. Anyway back on the case now, will be slow, but hopefully done by the end of summer.
I've got all the body parts together now, although some need some work. I've also decided to get someone else to paint it now otherwise I'll never get it finished.
I was looking at Mick Neill at Custom Paint Studio to do the job - like the idea that he'll do the dry build and all that. If anyone has got any experience of Mick's work I'd like to hear it, but looks good from what I've seen.
Also started putting the engine back together so it started from this:
stripped down and main engine parts cleaned
Now at this point
There'll be an Imola going on, but I stopped at this point because it dawned on me I'd need a wide small end bearing, which I need to get, amongst a few other odds and sods.
So -- hoping to make better progress this year....
keep it up you'll get there :D
psychedelicropcircle
And you may have to chop the battery tray off to get your carb on.
Devlam
Thanks yes -- battery tray removed since that pic was taken.
The thing that's buggin me at the moment is trying to get the handle on the side panel pointing forward.
New clip & handles, everything looks symmetrical but one side points forward and this side point up slightly.
It may be an issue with the side panel, because on the side that's ok there's a gap of about an inch between the panel and the floorboard support strut -- on the other side there's almost no gap. If I pull the panel out the handle does seem to go down a bit and point forward more.
Does that make any sense? :? Any ideas most welcome.
Note the panels were copper plated and then blasted or something - this is how I got them. I'll let the painter sort that out ;)
Chrs, Mark.
    Users browsing this forum: No registered users and 61 guests
